Old 3-Feb-2015, 8:36 PM   #2
BigDaveyL
Originally Posted by shoredweller View Post
Had reasonable reception using Channel Master 7777 mounted on a 10' antenna, outside on the roof. Didn't have it grounded and lost the signal after a wicked storm. Two questions:
1. Is there anything on the market that would work better than the 7777.
2. What's the best way to ground the antenna/amp to protect it in the future.
BTW, my signal report is attached below:
ttp://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d2c158f9d826ae6
Any/all help would be appreciated.
Thanks,
Shoredweller
The 7777 still has the highest gain/lowest noise, as far as I am aware.
The easiest way is to run your coax to a ground block very close to where it enters your house. Then you need some grounding wire. You then need to connect the grounding block to your house ground. Also, you need to run another ground wire from somewhere on your mast/antenna to your house ground as well. The grounding wire needs to be as short and direct as possible.
BigDaveyL is offline   Reply With Quote
