"Auto Scan" functions well in some cases, in other cases it fails completely... It depends on the TV manufactures firmware. When scanning for channels, use the "Air" or "Antenna" mode to be certain the TV is set to use the digital format for over the air broadcasts. "Cable" mode uses a different signal format and won't decode any digital OTA signals.
If needed, do an online search of your TVs model number plus the key word, "manual".
