Okay I have to add my two cents no technical stuff just simple real channel 9 is very powerful you basically can pick it up with a rabbit ear outside in a clear area. I pick up Real channel 29 and 15 they're the same broadcast wxsp cd And woms 29 same programming from what I can tell I just turn off channel 29 and use 15. Most likely there's no need for a bunch of antennas I know it's hard to make the bowtie if you don't have time but I assure you you'll be happy with the 10 inch whiskers the only thing you might not get is channel 9 if you're pointed south east with one antenna I posted pictures of the antenna I'm using now and with the added long wire on my reflector I also pick up channel 9 now as well as everything else Southeast. that is just with the one ugly do it yourself eight Bay bowtie. antenna.... Lol
