Old 31-Jan-2015, 10:28 PM   #13
Tim
I use a telescoping mast that is ground mounted and then bracketed to the eave of the house as you describe and it works perfectly. Makes a very solid support system. I had planned to use it for a ham radio antenna but ended up using it to try out OTA TV.
