Old 31-Jan-2015, 8:58 PM   #11
DaveSmithe
Thanks GroundUrMast and timgr!!
what do you think about this: instead of mounting via eaves mount ... installing two 10' poles or a 21' pole (both chain link fence top rails), installing the pole in the ground (6" to 1' down, cemented in), with an eaves bracket near the top of the roof to help support the pole ... running the grounding from the grounding block to the electrical system grounding system.
Would look something like this - forgive the non-artistic child-like writings-Win 7 snippet tool is not friendly!
it is roughly 15' from the ground to the peak of the roof. Installing it 6" to 1' in the ground would give me roughly 5-6' of pole to work with.
Here are a few images of what I was thinking as well as 2 images of our home (first one facing south), second one is a view, basically of what the antennas will be "looking" through.
DaveSmithe is offline   Reply With Quote
