Looks like the older section of St Charles. DB4e territory due to some hills.
Get the antenna placed so that you have the best available view across the arc between 147° and 178° (in the direction of Affton to House Springs). Avoid placing the antenna behind trees, other buildings, or your own roof. Do not drill any holes until you have satisfactorily tested reception, otherwise, if you call us for assistance, the first thing our techs will tell you is to move the antenna and try again. Usually, if you focus on KETC, the rest will get dragged along.
Sorry, don't have any idea about the WMC issue.
