Old 31-Jan-2015, 3:35 AM   #5
DaveSmithe
I was reading about the Antennacraft Y5713 and one site says:
"This antenna has a 300 Ohm output (twin lead) output, and requires a 75 Ohm transformer if coax cable is to be used."
Will the RCA TVPRAMP1R you mentioned accomplish this?
Oh and I am sure I know the answer to this will be to experiment, but would it matter if the DB4e is above or below the Y5713?
I'd like to try and use the current DISH pole but I am rethinking this to maybe taking that assembly completely down and instead use an eave's mount such as http://www.amazon.com/Winegard-SW-00...dp/B001DFTGUQ/ and the 5' pole mentioned on the same page: http://www.amazon.com/WINEGARD-TB-00...dp/B001RU3JG4/ ... considering the DB4e is nearly 40" high.
DaveSmithe is offline   Reply With Quote
