PA. DTV reception
If you think overload, simply turn the antenna to face the rear of the antenna toward the signal. That will put that notion to rest. If the problem is still there, electrical interference is possible. You need to determine if it's in or outside. To test for inside you can try turning off the power in the home and use a battery operated set or power up with a UPS if you have or can borrow either. I have found outside sources such as electric fences, or arcing power transformers to be the prime suspects. Inside I have found some LED replacement light bulbs to generate interference . Found one from Home Depot that shuts down my VHF.
Good Luck!
