tripelo,
It’s obvious that you put a lot of work into this professional caliber test report. I wish more people would take the time to pictorially depict their test setups like you do. Clear, concise & helps answer questions generated while reading your reports.
I’d be really pleased if I had your signal environment. My strongest signal of interest is ABC, channel 7 @-87.0 & 2-edge to boot. Box Springs Mtn. 3.5 miles out my back door and in-line with my LA stations is home to numerous communication towers, a channel 26 PBS TV station, several FM broadcast stations, a 2-Meter repeater that just booms in on my TV antennas plus I also pickup four NOAA weather channels with my LA array.
One of the items I found to eliminate some of the unknowns in my testing was the inline Channel Plus LPF-750 Low-Pass Filter. It’s basically a 0 to 750 MHz band pass filter I use to remove the cellular signals emanating off Box Springs Mtn.
http://www.solidsignal.com/pview.asp...ce=google_base
The only amplifier that I’m aware of that filters that portion of the spectrum is the new Antennas Direct Juice. ADTech did an excellent write-up on that amp here:
http://www.digitalhome.ca/forum/show...01#post2406201
More preamp test data to be posted later.
Looking forward to your follow-on.
