Old 28-Jan-2015, 11:06 PM   #9
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
Originally Posted by timgr View Post
Potentially you could get a DB8e and remove the reflectors, as mentioned above for the DB4e. That might be better than pointing the panels 180 degrees apart.
Be sure to distinguish between the DB8, the DB8e and the DB4e. The "e" antennas are more recent designs, optimized for the narrow bandwidth for TV that the FCC mandated in 2009. The DB8 is an older antenna.
Which parts of the DB8e/DB4e antennas are the "reflectors"?
...and, is a DB8 antenna just as good? I'm guessing if it is older, it would be less expensive. Here, my FCC ignorance is showing. I don't know what the 2009 mandate did. It could have been something to prevent lawsuits, or it could have provided great TV viewing benefits.
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
