Old 28-Jan-2015, 10:42 PM   #8
timgr
Originally Posted by jp2code View Post
Is there any real benefit with that technology, or does it just use fancy gizmos to trick ignorant tvfools into spending more money?
Heh.
ADTech (Antennas Direct Technician) is a regular here, and provides very good advice to a lot of people, without uncritically promoting his company's products.
The DB8e is a great antenna. It's basically two DB4e antennae mounted on a frame so the panels can be pivoted, and both panels coupled into a single cable. AD provides excellent technical specs on their antennas - take a look https://www.antennasdirect.com/cmss_...s/DB8E-TDS.pdf from https://www.antennasdirect.com/store...V-Antenna.html
It's an excellent antenna. When both panels are pointed the same way, it's significantly more sensitive than a single DB4e. And, the two panels can be aimed in different directions at a somewhat lower sensitivity. Up to you whether the extra expense is worth it, but it does what it claims to do.
Potentially you could get a DB8e and remove the reflectors, as mentioned above for the DB4e. That might be better than pointing the panels 180 degrees apart.
Be sure to distinguish between the DB8, the DB8e and the DB4e. The "e" antennas are more recent designs, optimized for the narrow bandwidth for TV that the FCC mandated in 2009. The DB8 is an older antenna.
