Old 28-Jan-2015, 8:06 PM   #1
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
Joe's Antenna Suggestion
We will be moving to a new house within the next few months.
It has an old VHF/UHF antenna on the roof, about 30 or 40 foot off the ground.
The TV Fool data is here:
http://www.tvfool.com/?option=com_wr...2c15dc5fca37fc
As you can see, the TV Stations are all around. There is a good grouping of them going out at 75° True Azimuth, but most of those are getting too far away to pull in clearly all the time.
I'd like to replace the old, existing antenna with something that will do us the most good without a rotor.
The following Real Channels are standard viewing: 31 (FOX), 7 (ABC), 22 (NBC), and 18 (CBS).
I would like to be able to also pull in 21 (CW) and 24 (PBS) year around (not just after the leaves fall off of the trees).
Would I be better served with:
The DB8 would likely not be great for Channel 7 (ABC), but that signal is strong enough that we can pull it in at our house now without a VHF-capable antenna.
SPOILER: I am using the Antennas Direct DB8e with the Stellar Labs 30-2475.
~Joe
Avoid Sears Home Improvement!
Last edited by jp2code; 5-Jul-2017 at 10:58 PM. Reason: TV Fool deleted my old image
jp2code is offline   Reply With Quote
