Old 28-Jan-2015, 6:51 PM   #13
Consider a cheap CS600 available at some Radio Shacks. The gain looks low for WPVI, but the database does not use the STA power of 64.9 KW of circular polarization that WPVI is actually running. One trick for WPVI is that the antenna may be placed with the elements vertical or even tilted to pick up a good signal
