Old 28-Jan-2015, 6:48 PM   #3
tomfoolery
I would just use a cheap rabbit ears and UHF loop combo from Radio Shack (unamplified), or at most the Terk HDTVi (also unamplified) which has some real directionality to the UHF portion, but still has a VHF dipole similar to all other rabbit ears types. I've used the $15 RS antenna, with a very similar TVF report to yours, similar signal strength and distance (also LOS), and only switched to a large antenna in the attic to get some of the more difficult stations. It was receiving all the local stations from the ground floor, on the wrong side of the house, looking through a lot of walls, wiring, and kitchen appliances.
But my VHF in the attic is still a dipole from a portable TV, which just hangs by its twin lead from the UVSJ which combines the UHF (DB4e) with the VHF (set to a length that corresponds to the two channels it receives).
For $15, it's worth trying. Oh, and the $10 RCA rabbit ear unit with the rectangular UHF loop from Home Depot also worked, but my FIL has it now. Either one is returnable, so no real risk as far as I can tell.
tomfoolery is offline   Reply With Quote
