Old 28-Jan-2015, 6:11 PM   #12
Originally Posted by signals unlimited View Post
I have several installations using the Y5713 in area receiving real channel 6 quite well with even less signal than showing on your report for Channel 6. One of these installs is in Frackville. I would give it a shot, on the roof with a pre-amp.
That reminds me of several occasions where a preamp located as close to the antenna as possible (the shortest coax jumper that was practical) appeared to isolate the high VSWR from the down-lead. This is one of those possible exceptions to the generalization that a preamps' job is to deal with loss on the downstream side. There's almost always an exception to a given 'rule'.
