Old 2-Jan-2011, 1:55 AM   #4
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You have access to both Boston and Providence. Boston is all UHF, but Providence is a mix of VHF high-band and UHF stations. The two cities do not lie in the same axis, so there are a couple of ways to proceed. If you want only one city you can put up an antenna aimed at that city. You will need a VHF-high-band plus UHF antenna for Providence or a UHF only deep-fringe antenna for Boston. I suggest using a preamplifier in either case, since you will be powering multiple TV sets.
Alternatives include using one deep-fringe VHF-high-band plus UHF antenna and include a rotator to turn the antenna between the two cities. This is the least convenient way to watch programs from both cities, as it would be necessary to turn the antenna to see all your TV stations, and if you want to watch different programs from different cities, this installation offers the least flexibility.
Another more expensive solution, but one that will facilitate watching either city simultaneously would be to use 2 antenna on the same mast: one aimed at Boston, and the other aimed at Providence. You would need to use 2 preamplifiers, one for each antenna. Feed the output of the power supply of each preamp to a 3 or 4 way splitter, then run one cable from each splitter to each TV set (2 cables total to each TV). At each TV set, install an RF A/B switch, which will allow you to switch between the antenna for either city. While this may be a bit more complicated, it assures that you will see interference-free reception from both Boston AND Providence.
Once you decide which route is the best one for you, we can discuss specific equipment choices for your situation.
