Old 28-Jan-2015, 4:45 AM   #31
HDTV-OTA
@GroundUrMast
Thanks for pointing out the tuner configuration - numerous times, I attempted scanning on both “Cable” and “Antenna” settings to rule out the unknown.
You stated, “If we were neighbors, you’d see a DB8E and Y10713 above my roof or on a tower”
Your antenna suggestion is Exactly the kind of information I’m looking for.
If one needs a house built, one might confer with a carpenter/builder.
If one needs 6 acres of steel sovereign territory, carrying 90 fighter jets, with 1 million pounds of laser guided ordnance, parked off the coast of a foe, then one would call on the US Navy.
That’s the reason I’m going to the Antenna Reception Pros.
A couple of preamps to consider... The Antennas Direct PA-18 (intend for weak signal area only) and the RCA TVPRAMP1R (more of a universal application design)
Yeah, you mentioned the new "Juice" preamp from Antennas Direct. I just searched and below is link with a video and the SPECS: http://www.antennasdirect.com/blog/tag/pre-amp/
FULL 19 dB Signal increase on UHF stations; 17.5 dB on VHF
2 dB noise margin
Cell Phone and Data Filtering
Includes Power Supply and DC Power Inserter & Mounting Straps
Easily installs in most homes/apartments.
The JUICE Preamp is now available and ready for shipment.
PRICE: $79.99
It looks promising, designed well, compact, and seems to be built well.
Thanks for bringing that for review.
Wish you all the best and a God speed in your recovery!
HDTV-OTA is offline   Reply With Quote
