Old 28-Jan-2015, 3:25 AM   #15
Thanks for the live links. The path profiles confirm you have very flat terrain so there is less concern about the warning, "Address was only resolved to block level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates."
StephanieS' suggestion re. the DB8E and ADTech's input strike me as 'spot on'. One could also consider adding an Antennacraft Y10713 if either WCIX or WILL are desired.
