Old 27-Jan-2015, 4:46 PM   #27
5. Regarding your test with the CM4228, it would suggest that *something* was defective. Balun, coaxial cable (especially if not new), cabling configuration perhaps, or something along that line.
To that list, I would add, check the tuner configuration... again. If set to 'cable' or 'auto' rather than 'air' or 'antenna' you would either certainly fail to see any or likely fail to see any OTA signals.
@HDTV-OTA, If we were neighbours, you’d see a DB8E and Y10713 above my roof or on a tower.
A couple of preamps to consider... The Antennas Direct PA-18 (intend for weak signal area only) and the RCA TVPRAMP1R (more of a universal application design)
The specs of the new "Juice" preamp from Antennas Direct are very good for a 'universal fit' preamp... I have a sample in hand but need to finish recovering from recent surgery before I can safely get on the roof to tilt the mast down...
