Old 27-Jan-2015, 4:32 PM   #32
JGoodwin
ADTech- Before I got your response I called antennas direct and spoke to the tech department. I thought it would be easier to talk to you directly not knowing there are multiply people in the tech department.
They also looked at me signal analysis and they came up with: taking down the DB4e and putting up a 91XG Uni-Directional Ultra Long Range.
Which antenna should work better? The 91XG has more gain than the DB4e.
Any suggestion on preamp antenna combos out of those two?
In the mean time I also ordered a RCA preamp and will move the antenna to the North gable of the roof.
JGoodwin is offline   Reply With Quote
