Install an FM filter at the input of the preamp. The one from Radio Shack should be fine, item # 15-0024, about $5. You have a TON of FM within 5 miles and, while the RCA is "pretty good" in not overloading from FM, it is not bulletproof. Make sure the internal trap is also set to on or in.
