I'm using a similar bracket type, supporting a 10' section of mast. There is 7 to 8' of un-guyed mast above the top bracket. With a CM3016 antenna at the top, I get some wobble in high winds, I would not put a larger antenna up there without guys. I would recommend guying each section of a multi-section tubular mast.
Both of the antennas you are using are quite a bit larger than the CM3016 (and more expensive). I would be far more comfortable guying the mast that has to carry all that wind load.
