Old 1-Jan-2011, 5:33 PM   #1
hd28vsb
Will an eave mount support work for this setup ?
If I use a Channel Master CM 9030 Adjustable Eave Mount that is securely mounted and use a 1.250 sectional mast , how high can I safely go above the mount ? Would like to use 2 antennas , a Antennacraft HD1200 VHF\UHF that I currently have and add a 91XG on top of it. Will I be able to do this without guywire supports. I believe I would need a min. 4 foot spacing between antennas.
Thanks
hd28vsb is offline   Reply With Quote
