Old 26-Jan-2015, 7:08 PM   #5
pigeonx
Originally Posted by StephanieS View Post
Hello PigeonX,
Your report looks pretty good for Springfield and Decatur signals. If you have clear pathways in the below headings, I can see a Antennas Direct DB8e mounted outdoors with a panel pointed to each heading would work nicely.
A couple questions first - What type of Philips antenna were/are you using? Second question - Is your 180 and 355 magnetic headings obstruction free? Meaning no trees or buildings blocking that direction.
Cheers.
Stephanie, 180 and 355 both look clear. 355 might have part of a tree in a way, but mostly looks clear. Antenna I currently have looks like Philips MANT940.
When it comes to the Antennas Direct DB8e, what do you mean by "panel pointed to each heading"?
pigeonx is offline   Reply With Quote
