I am not sure that I follow you. KMEX is on channel 34 with virtual channels 34.1 & 34.2. You said earlier virtual channels 38.1, 38.2 & 38.3. Could it be that you are picking up KPMR on real channel 21? I think you have the back of the antenna pointing pointing at 80 degrees. Turn it around. The little bow tie shaped pieces are the front of the antenna. The wire mesh part is the rear. Does that help?
