Old 25-Jan-2015, 10:56 PM   #3
Being on the 9th floor is good, that gives you nearly 100' of elevation.
However, what maybe more important is which direction you have windows facing. If your building is steel and concrete and your only windows face opposite the direction of your desired signals, then you can easily find yourself out of luck unless you can catch a lucky reflection off some other nearby structure.
