Thank you ADtech and Pete. Your comments are appreciated.
Originally Posted by ADTech
Since all the MER readings were with 0.5 dB, it's pretty much a statistical dead heat…
That is a possibility.
…No one would ever notice any difference under typical customer reception conditions…
Most would probably agree.
…If you use a wider scale on your bar graph say from 15 to 35, you'd have a very gradually sloped line, almost flat, around the 30 dB line.
Yes
Originally Posted by Pete Higgins
...found two amplifier designs that don’t show this overload issue, the RCA’s and my various PCT drop amplifiers (MA-B1015-1A, PCT-MA2-4P & PCT MA2-M)...
Interesting experience with preamps and drop amplifiers.
As both you and ADtech seem to understand and appreciate, in many cases, the dynamic range of a preamp is a strong factor contributing to overall satisfactory performance.
…interesting to compare the dynamic ranges & strong signal handling characteristics of the various offerings…
Yes
