@ Pete, thanks for posting TV Fool report. Is that a picture of your array, Xtreme Signal (HDB8X) stacked with a VHF antenna above and below? Nice. Any thoughts on stacking some 8 Bays antennas for my location?
@Jake V, Thanks for suggestion/response. Many recommend the DB-8 for pri UHF. Sure, as you mentioned, it would be great to receive channels both NW @ SE - almost directly 180 degrees opposite each other. The 91XG…. stated that it will not reach channels both NW & SE? After reading many forum posts and research, I was considering this 91XG to be a very hopeful UHF antenna.
GroundUrMast, Thanks for your the response. The DB8E is a nice antenna and the reflectors serve a purpose, especially for longer directional reception. Question: How would the Y10713 compare to a very large size UHF/VHF yagi with regards to distance, channels received and overall performance?
Thanks again to any and all responses – much appreciated.
