Old 24-Jan-2015, 9:55 PM   #15
HDTV-OTA
@ Tripelo - Nice work
Re. http://forum.tvfool.com/showthread.php?t=13236&page=5 @ Tripelo - Nice work. Thanks for posting the Signal measurements from several commonly used preamplifiers. It interesting that there is very little difference for the MER measurements. But, a much larger difference UHF output signal strength. That good information many can find useful when buying amps. Given the cost difference of these amps, the RCA seems to be a good choice.
Mr Higgins added useful point that the RCA is immune to strong FM overload and saw no notable difference in reception in his array.
I'm between 61 - 70 miles from the Cedar Hills (DFW) antenna farm, and I'm trying to identify an antenna to reach.
Given you guys knowledge and experience and without giving out any trade secrets - could I ask what antenna(s) setup would you recommend for these UHF & VHF channels?
1. Winegard HD8200P
2. Channel Master 3671 Crossfire
3. XG-91
4. Antennacraft SuperG 1483 (the stacked Hooverman version)
5. Stacked CM-4228HD
6. Stacked DB8’s
Thanks in advance for your help and advice.
HDTV-OTA is offline   Reply With Quote
