Old 23-Jan-2015, 11:32 PM   #7
Originally Posted by mainer View Post
I was looking at the Channel master telescoping antenna mast for mounting the antenna. What height do you recommend for the DB-8e antenna.
The ideal location/height is usually that which clears nearby obstructions such as trees and buildings. If there are no obstructions to deal with, your report indicates that many signals are LOS (line of sight) which should make them easy to receive without taking extraordinary measures.
