Thread: NE Seattle
Old 23-Jan-2015, 3:32 PM   #1
Tristan
NE Seattle
http://www.tvfool.com/?option=com_wr...2c15adddacf9dc
This has been a long, very intermittent project due to time constraints. Previous answers to my posts over one year ago were very helpful in getting me this far!
Currently have a single antenna/cable run of about 30-40 feet to one TV (no plans for more TVs, but would be willing to add additional antennas which I know is likely needed). Yes there are trees in the way, nothing huge and close, and yes I'm "behind" a hill from Capital Hill/Queen Anne Hill groups (the groups at ~193 and 216 true compass direction)
I would like to get real channels: 38,48,39,31,22,33,46 (UHF, virtual 4,5,7,16,22,33,46) and 9,11 (VHF). Only desire 13 if I cannot get 22 (which co-broadcasts 13). 27 (virtual 28) would be nice, and I have gotten it at times.
Experience/trials so far:
-best success with DB4e at about 15 feet above roof (not sure that is a realistic permanent solution for me), got everything but real 38 (virtual 4) from UHF stations listed above.
-I've noticed wide variation in tuners (I've tried 3 different televisions, one DVR with built in tuner, and the HomeWorx HW180STB) with identical antenna arrangement
-I've noticed wide variation in antenna location (I have a flat roof and can easily walk around). Purchased a portable RCA TV to scan from rooftop as cheap alternative to a spectrum analyzer.
-I've noticed fairly substantial improvement if I tilt the antenna up about 15 degrees
Tentative plans to add a Y5-7-13 and aim towards 9 & 11, combined with UVSJ: VHF is not the problem (9 & 11 seem easy to get). Ideally one UHF for everything else. A few questions:
1) Anyone have experience with the Digiair Pro ATSC spectrum analyzer (or something similar?). The RCA portable TV works reasonably well, but is slow to re-scan and does not give real-time information. Pricey, but I might have crossed the obsession threshold enough to purchase.
2) I understand combining two antennas for UHF results in at least 3dB signal loss, I think that is roughly half the strength? I don't really have a good sense for how that would affect reception (does the listing of NM(dB) or Pwr(dBm) in my TVFR help predict?).
3) The XG-91 has a mast-clamp system that allows tilt up, but I'm hoping I can find an optimal site for the BD4e (or something multidirectional, maybe even DB8e). Is there any readily available clamp solution that will allow me to tilt the DB4e or DB8e up 10 or 15 degrees? (mounting the mast at an angle seems difficult and less safe).
4) It seems odd to me that stations broadcasting from very similar/identical locations with similar power could have such variability in reception... is this due to frequency differences that cause different amounts of reflection and or refraction of the signals? For example, virtual 4,5,7,16 (real 38,48,39,31) all transmit from very similar locations, with kW ranging from 500-1000... yet are all very difficult to receive from the same antenna location. Any advice?
Thank you!
Tristan is offline   Reply With Quote
