I would encourage you to try the Y10713, but it's really unlikely you will be able to receive WMUR unless the antenna is mounted high in clear air, unobstructed by trees and buildings.
I get WMUR very reliably in Medford. On my plot it's 2-edge at 16.1 dB NM, 45 miles away. However, I also reliably get WENH 11 at -10.4 dB NM, 51 miles away, which should be impossible. I'm pointing right at WENH, and WMUR is 27 degrees off-axis.
The Y10713 isn't very expensive... give it a try. Get some help, rig it high on the roof, and see if you get anything. Then if WMUR is strong, you could try moving it to the attic.
