It looks as if you're blocked by terrain... I share Tim's concern about an attic mounted system. The low signal levels shown in your report strongly suggest mounting outdoors, clear of all nearby obstructions and for using a deep fringe combination such as an Antennas Direct DB8E + Antennacraft Y10713.
If there is no high powered FM signals close to you, the Antennas Direct PA-18 is a remarkable deep fringe preamp. Another option is the RCA TVPRAMP1R, it's much more tolerant of stronger signals though it will not have the outstanding noise performance that the PA-18 offers. The PA-18 would require a separate UVSJ to combine the UHF and VHF antennas ahead of the preamp input.
