Old 20-Jan-2015, 8:26 PM   #3
Jake V
OK, I had a few minutes and looked up the rest (all the green and yellow at 257 and 345):
KVAL-DT 13 (CBS, This TV, Grit)
KEZI-DG 9 (ABC, Me-TV)
KMTR-DT 18 (NBC, CW)
KEPB-DT 29 (PBS)
K19GH-D 19 KSLR (Fox, MyN)
KHWB-LD 38 Religious
KLSR-DT 31 (Fox)
K21FS-D 21 KEPB (PBS)
KEVU-CD 23 (MyN)
KOAC-DT 7 (PBS)
K11GT-D 11 KEZI (ABC, Me-TV)
KORY-CA 41 ??
KAMK-LD 49 KBLN (3ABN)
This information should make it possible that you don't need the stations from the translators to the south. As above, your easiest solution is to use a DB-8e with one panel pointed at 257 degrees and the other at about 345 degrees for the UHF channels, with a Y5713 at about 345 degrees for the VHF HI channels.
