Old 20-Jan-2015, 12:13 PM   #5
The report is showing a 14.1 for fox but it is showing as 7.2 on my TV - in fact I only get 7.1 and 7.2.
Fox is on BOTH 7.2 (stretched SD) and 14.1 (HD). TVFool does not address the sub-channels so they won't show up on the charts.
How close to the antenna should a preamp be? Or does it matter?
Yes, it matters. To keep the system noise figure a low as possible, keep the lead between the antenna and the preamp as short as feasible.
All of our antennas will fit a 2" OD pipe except the DB8e or C4. Those two are limited to 1 3/4".
Very weak UHF signals and trees are usually incompatible with reliable reception.
I don't see any mention of what you're currently using.
