Old 20-Jan-2015, 12:08 PM   #12
No static at all
No static at all's Avatar
Originally Posted by HDTV-OTA View Post
TVFool indicates I have 3 stations 10 miles away. Will these FM station interfere with any of my channel reception?
Yes, 91.3 KDKR does raise a concern for channel 8. A Radio Shack FM trap should adequately attenuate the signal if you are at least 5 miles away from the transmitter. You could also try a stronger FM trap, but I have personally found the Radio Shack model to work well above 90 Mhz.
Of course this is if KDKR is really the issue as the 4228 is many times OK on VHF, but unpredictable as it is basically a UHF antenna.
