Consider that an increase in signal strength does not automatically translate into an increase in signal quality. Most TV tuners that provide a 'signal strength' indicator are actually reporting some expression of the digital error rate which can be made worse if distortion and noise from an amplifier is added.
Amplifiers depend on a relatively clean signal from the antenna... The amplifiers job is to 'push' a stronger copy of that signal through the losses in cable and splitters down stream. Amplifiers can not/do not 'pull' signal from the antenna or air.
