Old 19-Jan-2015, 3:27 PM   #5
ctresident
Need Help with signal amplifier
Thank you for all the help. I am now getting a spotty WCBS from Long Island, depending on weather and other unknown variables which is as good as WFSB for my purposes. I am however losing channels when split to the 2 TV's. Can you recommend an amplifier. I do not know if I there are ones that can adjust the amplification, and also as the weather gets warmer I will be going from the attic to the roof with the antenna and I may mount the amplifier outside. I would want to know which one would make sense for outside and which if I put the amp inside right after the cable comes into the attic. Thanks again.
ctresident is offline   Reply With Quote
