Old 19-Jan-2015, 1:24 PM   #6
timgr
With an aluminum exterior building, you can pretty much forget about the signal penetrating it.
Yep. Look up Faraday cage.
Maybe you could buy some rabbit ears and try them on your balcony - http://www.amazon.com/RCA-ANT111F-Ba...sr_1_1?ie=UTF8 - you should be able to pick up these or similar at your local WalMart or home center. Then get a long cable and take them out on your porch. Experiment with placement and direction. Look here for some ideas http://www.kyes.com/antenna/rabbitear.html
