Old 18-Jan-2015, 10:50 PM   #8
If you can avoid aiming through trees or other obstructions, an HBU-33 or Winegard HD7694P should provide a premium solution. Your description of the coax leads me to the conclusion that the coax and existing antenna are long past due for replacement.
As already mentioned, there is plenty of signal power in the air, no amplification should be needed even if you're splitting to several TVs.
