Old 18-Jan-2015, 3:22 PM   #1
billg
Help pulling channels from 2 directions
Hello all,
I've followed the suggestions/directions from an old thread I posted:
http://forum.tvfool.com/showthread.p...ed=1#post46817
to get channels from both the West Palm Beach and Miami metro areas. I've installed a DB4e antenna without reflectors on a mast about 12' above the roof of my home. Per the Antennas Direct suggestion, I added a VHF dipole above the antenna. The dipole is oriented due N/S, and the UHF bowties are oriented due E/W. There are other trees/buildings in the area, but generally we have a clear shot to the south of us and a minimally obstructed shot to the north.
Unfortunately, while we do tend to pull the Miami stations well, many of the West Palm-based stations either don't tune at all, or will tune for the first second or so before going out. I presume this means that I have just marginal of a signal enough for my TV to tune.
Here are my maps:
http://www.tvfool.com/?option=com_wr...d243a818aae652
http://antennapoint.com/antennas/sho...&commit=Search
I *might* be able to add another foot to my mast, but much beyond that is going to cause technical difficulties, and look ridiculous from the front of the house. I'm having the most difficulty tuning:
12.1 - CBS (12 mi north)
42.1 - PBS (13.5 mi north)
25.1 - ABC (49 mi north)
10.1 - ABC (35 mi south)
I used to be able to get 12 and 25 very consistently, and with a good picture. These days I occasionally am able to tune 25.1 and 12.1 fine, but usually not (or only for the first second before the TV drops out). The system is well grounded, and I'm using a pretty short run of cable from the antenna to the TV (well under 100', probably more like 60 or so). The coax cable is new, and high quality.
Before I go back up on the roof and try turning it in all sorts of directions (which is complicated by the fact that the VGA dipole sits on top of the whole rig, so I need to take it down to adjust, and then put it back up), I was wondering if there were any general suggestions as to how to orient, whether I should use some kind of amplifier, etc., or if there is a "best way" to test without going up to the roof, rotating 1 degree, and then going back to the living room to check all the channels.
Any suggestions would be appreciated!
billg is offline   Reply With Quote
