You need a window that gives you a view to the west southwest if you want a prediction for reliable reception. Otherwise, you are left with trying to catch a reflected signal out that north-facing window or relying on signal penetration of your building, neither of which allows for any expectation of a relivable prediction.
Your best bet is to pick up a simple UNAMPLIFIED loop and rabbit ears from somewhere like Radio Shack (while they're still in business) and experiment with that.
Good luck, your results will depend on both persistence and luck.
