Old 31-Dec-2010, 12:05 AM   #3
scott784
I appreciate your reply. Do you have any suggestions on mounting the antenna? My home is vinyl sided with no brick or chimney. I'd like to mount it as high as possible. Would a large antenna, such as the one you mentioned, have enough strength to be mounted with brackets tied to my roof soffit? I know this procedure is done with satelite dishes but not sure if it would provide enough strength for a large antenna.
scott784 is offline   Reply With Quote
