Old 15-Jan-2015, 11:29 AM   #5
No static at all
No static at all's Avatar
Originally Posted by Ben Myers View Post
If you can't go any higher, try lower, or a different location altogether.
Good advice as higher isn't always better.
How did you aim the antenna? I suggest first aiming with a compass & then fine tuning using the signal strength meter.
Do you have the antennas close to each other or anything else?
Any nearby airport(s)?
