Old 30-Dec-2010, 11:46 PM   #4
John Candle
Tv Antennas and Reception
I suggest a Winegard HD7082P antenna with a Winegard AP8700 preamp. The stations you will receive are to west north west . . WMYA 14 MyN MyNetwork is the odd one out in this reception situation , the transmitter is on the side of the antenna , antennas pick up the least amount of signal on the side of the antenna. So try and improve the reception by pointing the antenna at 339 degree magnetic compass , this will put the antenna at a angle to the transmitter. The antenna can be turned to the left and right between 339 and 288 magnetic compass to find best signal pick up. I do not believe the antenna will work in the attic , the aluminum backing on the insulation will block most of the signal and what does get through will be reflected all around causing bad multipath. The best place to put the antenna is on the roof.
