Your link to your TVF plot is corrupted.
Bottom line answer to your question is "Probably not". You can try an 8-bay, should one be appropriate for your locale, but its really a "Hail Mary" proposition. You could also try a second antenna at a different mounting location and, using a A-B switch, see if you can find a combination that allows one of the antennas to work better than the other during varying signal conditions.
