It's there.
Raise your elevation to 500' and allow the simulator to recalculate.  Unless you're behind a mountain, it should show up.  If you are behind a mountain, its calculated signal level may be too low to make the cut.
Ninth entry:
http://www.tvfool.com/?option=com_wr...2c15daa457c136
