Old 14-Jan-2015, 6:38 PM   #1
Jdruding
Any options left?
Hi all,
I posted here a little over a year ago and got some great advice, all of which I took, where I could. (eliminated wiring, splitters, amplifier, as issues) So, here is where i'm at: I have an Antenna’s Direct DB4e, a C2V reflector and an amplifier. My tuner is a TiVo Premiere. My antenna is outside, above the roofline, oriented in the right direction. Here is my TVFool info:
http://www.tvfool.com/?option=com_wr...46aef16aa5bafe
I still occasionally get break ups, particularly on Fox 29. Based on all of your help, i have concluded that my problem is a wall of mature (60ft tall) trees, about 50 ft away. There is no way i can get the antenna any higher and the trees aren't going anywhere.
So, do I have any options remaining? Could I upgrade my antenna? If so, what what antenna would you recommend that is better than what i have? Any other suggestions?
Jdruding is offline   Reply With Quote
