Old 14-Jan-2015, 3:41 PM   #5
rickbb
For how high you can go without guy wires you're best bet would be to ask the mast manufacture.
If you're building your own, there is some complicated math involved. Wind load deflection of the antenna X max wind speed X height of mast X type of mast material X thickness of mast material X, well you get the picture. It's all well above my last math class.
An 8 way splitter means 35db / 8 = 4db. Plus some more loss since the splitter is not 100% efficient. You may need an distribution amp instead of a plain splitter.
