Old 14-Jan-2015, 1:21 PM   #2
Jake V
1. This post belongs in the "Help with Reception" forum below.
2. Your TV Fool Report is only resolved to the block level. It is probably reasonably accurate for your location but you can make it more exact by following the directions at this link: http://forum.tvfool.com/showthread.php?t=14508
If your TV Fool Report doesn't change for your exact address you're going to need something pretty powerful (you have a lot of 2 edge, weak signals). And you have one VHF-HI Station (7-CBS) with the rest being UHF. A single antenna solution like the HBU-55 aimed at 165 degrees might not get the PBS station at 164 degrees (KOZJ-25).
But re-post below in the correct forum with an updated TV Fool Report for an expert recommendation.
